30 minutes ago, Ghostly224 said:
they are moving but they are low because im getting super low fps around like 60-70 fps on 1080 medium settings.
Pretty sure your GPU isn't being stressed at those settings. That's probably why the clocks are so low.
CPU: Ryzen 7 5800x3D || GPU: Gigabyte Windforce RTX 4090 || Memory: 32GB Corsair 3200mhz DDR4 || Motherboard: MSI B450 Tomahawk || SSD1: 500 GB Samsung 850 EVO M.2 (OS drive) || SSD2: 500 GB Samsung 860 EVO SATA (Cache Drive via PrimoCache) || Spinning Disks: 3 x 4TB Western Digital Blue HDD (RAID 0) || Monitor: LG CX 55" OLED TV || Sound: Schiit Stack (Modi 2/Magni 3) - Sennheiser HD 598, HiFiMan HE 400i || Keyboard: Logitech G915 TKL || Mouse: Logitech G502 Lightspeed || PSU: EVGA 1300-watt G+ PSU || Case: Fractal Design Pop XL Air
https://linustechtips.com/topic/1304974-rtx-3080-help/#findComment-14477268
7 hours ago, Ghostly224 said:
idk it might be that but why are the fps so low
What's your CPU?
Answer while also downloading this : https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Restart your computer in safe mode (in case of windows 10 otherwise google how to restart in safemode: by clicking on the windows icon of your taskbar then click on the "power" option which whill reveal options such "shut down" "restart" "sleep"
hover your mouse on the "restart" option (DONT click it yet) press the shift button on your left of your keeboard and hold it for like at least 5 sec (dont remember the exact time hold for a few seconds just to be sure) then click on restart.
Once you are booted in safe mode run DDU and completely clean any drivers amd or nvidia (its the default option if I remember correctly but just look for a complete clean option)
then restart your computer and visit https://www.nvidia.com/Download/index.aspx fill the options and download the game ready driver (next page is should have a WHQL next to the driver name)
install it.
restart your computer normally.
Then before starting rust do this on steam: https://steamcommunity.com/sharedfiles/filedetails/?id=760447682
After that start rust
If nothing changed then download OBS from here: https://obsproject.com/
do this and chose the option to advance (see the video to make sense of that)
capture your screen with OBS using nvenc while you are playing the game
How to do that?
upload it and link it here for us to see whats going on.
I
https://linustechtips.com/topic/1304974-rtx-3080-help/#findComment-14478130
What Cpu?
CPU: Ryzen 7 3700x,  MOBO: ASUS TUF X570 Gaming Pro wifi, CPU cooler: Noctua U12a RAM: Gskill Ripjaws V @3600mhz,  GPU: Asus Tuf RTX OC 3080 PSU: Seasonic Focus GX850 CASE: Lian Li Lancool 2 Mesh Storage: 500 GB Inland Premium M.2,  Sandisk Ultra Plus II 256 GB & 120 GB
https://linustechtips.com/topic/1304974-rtx-3080-help/#findComment-14478309
