Hi, i'm an openshot user, i got this trouble when i render my video. the first one is that i can't export with low quality otherwise the result would be an blank video with an injected audio, the second one is, render speed, i know i must use a powerfull GPU for it but can i get other ways than upgrading my GPU ?
this is my system spec : intel core 2 duo e6300, 2gb ddr3 low density RAm, intel G41 express graphics, lord G4X 775 ICH7 8712
https://linustechtips.com/topic/1304664-openshot-problem/
1. What do you mean by "low quality"? I don't use Openshot so is that some preset?
2. You would gain much more from upgrading your CPU (and possibly other core components too). You have dual core from 2006. Even getting some quad core like Q6600 would be better. And doubling RAM to 4 gigs.
Openshot documentation says it supports CUDA/NVENC on Windows. So GTX660 and up.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1304664-openshot-problem/#findComment-14475027
what i mean low quality is like (720p 30fps) and high quality is (4K 60fps)
https://linustechtips.com/topic/1304664-openshot-problem/#findComment-14477498
Your hardware is probably too old for handling that kind of stuff. Have you tried 480p?
https://linustechtips.com/topic/1304664-openshot-problem/#findComment-14477825
