CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  (£125.99 @ Aria PC)
Motherboard: Asus H81M-PLUS Micro ATX LGA1150 Motherboard  (£40.57 @ Scan.co.uk)
Memory: Kingston Beast 16GB (2 x 8GB) DDR3-2133 Memory  (£112.79 @ Amazon UK)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk  (£47.99 @ Aria PC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£51.98 @ Aria PC)
Video Card: MSI GeForce GTX 770 2GB Video Card  (£238.04 @ Aria PC)
Case: Cooler Master N200 MicroATX Mid Tower Case  (£32.99 @ Novatech)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£53.28 @ Amazon UK)
Optical Drive: Lite-On iHDS118-04 DVD/CD Drive  (£10.78 @ Scan.co.uk)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  (£69.96 @ CCL Computers)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  (£10.50 @ CCL Computers)
Total: £794.87
What do you guys think of this build, the PC is going to be mainly used for gaming, however I will also be recording/editing/rendering with it. I don't plan on overclocking this build. This will be the first PC I have ever built, so I want to get it right first time.
Would this be able to something like BF4 on ultra?
My budget is £800, but I can go a little over if you think it's worth it.
---Jacob Whitehead---
https://linustechtips.com/topic/130465-need-help-with-first-pc-build/
Make sure you have a backup wireless device encase that one does not work. I bought one myself and it caused countless blue screens of death.
CPU: i5 4430 PSU: XFX 550w Ram: 8gb Patriot Viper 1600mhz
Motherboard: MSI H87M-G43 Case: Fractal Design Define R4
SSD: 840 Evo 250gb, 512gb MX100 GPU: MSI GTX 980TI Gaming Cooler: Hyper 212 Evo
just go wit wired lan if you are going to be gaming and for that use case an AMD 8350 and a am3+ motherboard would make much more sense. that 15 with no overclocking at all will run out off puff very soon.
PC specs.3570k, asus p8z77m pro, 8gb corsair vengence 1600MHz, XFX 550w, seagate barracuda 1TB, MSI 660ti, cooler master k350, cooler master hyper tx3 evo.
recording gameplay with fraps
Are you just making gameplay videos?
Do post the pcpartpicker permalink--saves time.
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  (£105.59 @ Aria PC)
Motherboard:  Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard  (£99.99 @ Amazon UK)
Memory:  Kingston 8GB (2 x 4GB) DDR3-1333 Memory  (£52.98 @ Ebuyer)
Case:  Cooler Master N300 ATX Mid Tower Case  (£32.00 @ Amazon UK)
Power Supply:  EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  (£47.52 @ Scan.co.uk)
Wireless Network Adapter:  Intel 7260HMWDTX1 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  (£33.31 @ CCL Computers)
Total: £790.14
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-03-22 20:53 GMT+0000)
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($309.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ NCIX US)
Memory: Corsair Vengeance LP 16GB (2 x 8GB) DDR3-1600 Memory ($159.99 @ Newegg)
Storage: Intel 530 Series 240GB 2.5" Solid State Disk ($149.99 @ Amazon)
Storage: Samsung EVO 1TB 2.5" Solid State Disk ($459.99 @ Amazon)
Storage: Western Digital BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive ($194.99 @ Newegg)
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case ($105.98 @ SuperBiiz)
Optical Drive: LG BH16NS40 Blu-Ray/DVD/CD Writer ($99.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.99 @ NCIX US)
Other: Corsair Professional Series Gold AX850 Fully-Modular 850 Watt 80 PLUS Gold Certified Power Supply (CMPSU-850AX) ($179.99)
Other: Cooler Master 120mm Blue LED SickleFlow 2000 RPM Long Life Case Fan (R4-L2R-20AC-GP) (BUY FOUR) ($9.00)
Other: GeForce GTX 780 Ti
Other: NZXT 140mm LED (Blue) Airflow Fan ($32.20)
Other: ASUS MAXIMUS VI EXTREME LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Total: 1378.04£
You can find the parts yourself but thats the best you can get for what you want to do ;-)
CPU: Intel Core i5-4670 3.4GHz Quad-Core Processor  (£155.12 @ Aria PC)
Motherboard: Asus H81M-A Micro ATX LGA1150 Motherboard  (£37.94 @ Ebuyer)
Memory: Kingston Beast 16GB (2 x 8GB) DDR3-1600 Memory  (£111.31 @ Amazon UK)
Total: £819.89
Is this a good spec? I would be using this for gaming, recording with fraps and editing/rendering videos. Just wondering if everything makes sense to buy. I will not be overclocking this build btw.
Total: £819.89
Don't make multiple threads for the same build. Keep it to one thread per build. I'm merging the threads.
Total: £819.89
yes its good.but no need for i5 4670. get i5 4570 or 4440
