no helpful information is provided... sorry mate cant help
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
https://linustechtips.com/topic/1303960-will-it-compatible/#findComment-14468494
1 minute ago, SavageNeo said:
motherboard do not really matter.
pc case and psu does
psu and cpu is what mostly matters
My PC
https://linustechtips.com/topic/1303960-will-it-compatible/#findComment-14468503
4 minutes ago, jitman said:
just edit the the information need help
ah good ok
looking at it at first glance you will be fine with a GTX 1060 yes.
psu seems kinda sketchy tho, whats the product information about the "hyper 600"?
alltho I would recommend a psu and gpu upgrade if you want a major improvement, like maybe an rtx 2060 super or a gtx 1070 - gtx 1080 (ti)
My PC
https://linustechtips.com/topic/1303960-will-it-compatible/#findComment-14468515
14 minutes ago, GorujoCY said:
ah good ok
oh thanks,
what psu do i need to use ?
do i need the gold?
https://linustechtips.com/topic/1303960-will-it-compatible/#findComment-14468549
3 minutes ago, jitman said:
oh thanks,
do i need the gold?
i say up to at least 80+ bronze will do the work just fine
as for the wattage, it depends on which gpu are you going to get from what i have said, the minimum that you will see a major improvement is on the gtx 1070...
My PC
https://linustechtips.com/topic/1303960-will-it-compatible/#findComment-14468554
okay thankyou , it really help me
https://linustechtips.com/topic/1303960-will-it-compatible/#findComment-14468555
If the "600" in the psu name means 600 watts then yes your fine. Bronze vs gold just means power efficiency, bronze will run the same video card as platinum but will cost more in your electric bill as far as I know. I'm sure someone will correct me if I'm wrong on that
https://linustechtips.com/topic/1303960-will-it-compatible/#findComment-14469234
