1 minute ago, toni23 said:
I don't know I think it is the Northbridge
Well, it's a heatsink. Heatsinks exist to dissipate heat and thus it most likely is there for a reason and so you should put it back; check if the tab that's supposed to hold it in place is damaged and, if not, just simply push it back in place.
https://linustechtips.com/topic/1303252-is-this-a-problem/#findComment-14463016
I pushed it in and it's good now thank you so much.
https://linustechtips.com/topic/1303252-is-this-a-problem/#findComment-14463074
