so i have an rx570 and it overheats, i already tried reapplying thermalpaste and cleaning the card but no luck what so ever though i was able to lower the temps quite a bit by setting the max core clock voltage to 1060mV but it still has relatively high temps like in cod mw 2019 it goes around 75 to 83C, so at first i though that i should be fine just by sticking with the undervolt after seeing that it works with (most) games, in my situation, I had no problems until trying the game "A Way Out", i was playing with a friend and after a few minutes it restarted my pc, and after that happened i checked the temps while playing the game and saw that in the main menu it sitting around 65C to 71C and in game around 81C to 87C, so I suspected it is probably the fact that my pc case only has one fan and it also is just an exhaust fan, so if that is the culprit of the problem, how should i add more fans? my case is a Thermaltake Versa H23 which has a mesh front and for me it has two free fan slots on top....any help would be appreciated 馃檪
https://linustechtips.com/topic/1302666-overheating-problem/
What exact model of RX570 do you have?? If its a reference style card (blower fan) then, those temps seem the fall in the ball park for those cards. Perhaps you didn't use enough thermal paste or tightened the cooler back on properly?聽
Take the side panel off the case and run a game and see if temperatures improve. If temps come down, then you know there is not enough airflow coming into the case to help cool the graphics card.聽
CPU Cooler Tier List|| Motherboard VRMs Tier List||Motherboard Beep & POST Codes|| Graphics Card Tier List||PSU Tier List
Main System Specifications:聽
CPU: AMD Ryzen 9 5950X ||聽聽CPU Cooler: Noctua NH-D15 Air Cooler||聽RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18聽 ||Mobo: ASUS ROG Crosshair VIII Dark Hero X570聽 ||聽聽SSD: Samsung 970聽EVO聽1TB聽M.2-2280 Boot Drive/Some Games)||聽聽HDD:聽2X Western Digital聽Caviar Blue 1TB(Game Drive)聽 ||GPU: ASUS TUF Gaming RX 6900XT聽 || 聽PSU: EVGA P2 1600W聽 ||聽聽Case: Corsair 5000D Airflow||聽聽Mouse: Logitech G502 Hero SE聽RGB聽 ||聽聽Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky聽Switches聽 || 聽Mouse Pad: MAINGEAR ASSIST XL||聽聽Monitor:ASUS TUF Gaming VG34VQL1B 34"聽
https://linustechtips.com/topic/1302666-overheating-problem/#findComment-14458182
It is the refrence style card and im pretty sure ive used more than enough thermal paste and i have done this many times before too on other cards, ive also tried taking off the side panel and it seemed to have helped a bit but even with the side panel off it still overheats and resets my pc.... so is buying more fans enough to fix my problem or not?
https://linustechtips.com/topic/1302666-overheating-problem/#findComment-14458726
