Hi!
I have a problem with my pc.
the pc just shuts down on its own when im playing games, watching videos
What can it be?
Thank you for your help!
Jacob :)
PC Specs:
RAM: 12GB
CPU: AMD FX-6300 Six-Core Procesor
GPU: ASUS CERBERUS GeForce GTX 1050TI A4G
https://linustechtips.com/topic/1302468-pc-problems/
What are your temps and what PSU do you have?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14456746
This is only in Windows
GPU: 33 °C
CPU: 31 °C
In Game (Minecraft)
GPU: 45 °C
CPU: 44 °C
This was measured after 5 minutes of minecraft
And for the PSU:
I-Tec PowerGamer 700W
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14456761
3 minutes ago, Useless Soveriegn said:
When was the system built and when was your last windows install and last windows update
Last Windows Update was 1 day ago, Last windows install was 1 and half a year, I dont remember when was this computer built
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14457492
theres not alot to go off but if it was me I'd update my bios if needed, reinstall windows clean and see if the behavour presist if it does then its likely hardware related.
Kinda guess here and i basicly reinstall windows monthly so its kinda my go to solution .
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14457501
I Updated BIOS a 2 months ago but i cant reinstall windows, this is my Main Computer and there is all my work, games
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14457506
thats all i got dude, i reckon its software casueing some problems and answer to that is reinstall. Like you should find some trash harddrive and install to thatm test it that way if you really dont wanna reinstall on your current drive
I have a 1 TB Harddrive but there is Virus on it that can lock my BIOS and i dont want my BIOS To be locked. I wanted to use the drive for games and stuff as a upgrade to my PC But as i said there is a virus that i got from a email. Is there any way to erase the drive without harming my computer?
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14457521
ok follow theses steps
1.Move your work/game files to external/google drive or some simillar shit
2. Format your drive
3. Reinstall windows/redownload games
4. Deposit life saving into my paypal
5.Monitor system for issues
all steps optional except step 4
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14457524
But the worst thing is that the virus corrupted the windows on it and i cant get my files and BIOS Had problems with the Virus that when it tried to boot into windows it flashed and it restarted even when i reinstalled windows it was doing the same thing
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14457526
I sent a message but i forgot to click on quote so you didnt get notification.
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14457530
Follow instructions as shown
all might be well
Either way i g2g
peace out
I have a USB With Windows Installation on it i can format the harddrive but how can i do it? Im scared that the Virus on it will Harm my computer
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14457535
just install as normal
or to be more verbose
boots from the usb
install as normal
when u get to this screen
click your 1tb drive and click delete
select the newly created unallocated volume
then hit next, bam all your data is gone and windows is installing fresh
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14457540
boots from the usb
install as normal
OK I will try that this day and i will Send you a message about it
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14457544
Just now, Useless Soveriegn said:
no your boot drive will be completly wiped of all data. virus and everything else it wont be an issue
So this is what i will do:
1. I will unplug my SSD With my main Files
2. I will plug HardDrive
3. I will Wipe data on it
4. I will install Windows
5. I will send you a message and i will wipe it again so i can use it as a drive for games and my stuff
https://linustechtips.com/topic/1302468-pc-problems/#findComment-14457559
