9 minutes ago, Bharath1910 said:
I have 2 physical HDD 1 has Garuda Linux (Arch based) another one has Windows 10 when I boot into grub menu.. I can't see windows
What happens if you change the boot order in bios to boot to the HDD containing windows?
Attention is what makes life meaningful.
Also, please quote me for a reply. 🙂
https://linustechtips.com/topic/1302308-grub-menu-problem/#findComment-14455218
2 hours ago, mahyar said:
well its not much of surprise because they don't share a bootloader partition
This has nothing to do with the problem, grub can load an OS from any disk and partition (if it is a sensible one; it might not do something like booting a DOS-based OS from an extended partition etc.).
3 hours ago, Bharath1910 said:
It is very overwhelming for me... but thanks I will try to understand it
Post  the output of "sudo lsblk" and "sudo blkid" here, that way we can help.
The page can be daunting as it has loads of information out of which not all is relevant to you. To summarize the process is roughly:
  1. install os-prober (it is not installed per default in Arch),
  2. mount your windows partition and then
  3. run grub-mkconfig (as outlined earlier on that page).
With the help of above commands, people can probably give you the exact command needed to enable grub detecting Windows.
(in case you ever re-run grub-mkconfig, you need to remount the Windows partition less grub-mkconfig will overwrite the configuration without Windows entries)
https://linustechtips.com/topic/1302308-grub-menu-problem/#findComment-14456123
All you have to do is install os-prober:
sudo pacman -S os-prober
Then mount the Windows partitions, and run:
sudo grub-mkconfig -o /boot/grub/grub.cfg
https://linustechtips.com/topic/1302308-grub-menu-problem/#findComment-14456930
I can't mount those drives.. bcz it is NTFS
and it says unmounted and no option to mount it
https://linustechtips.com/topic/1302308-grub-menu-problem/#findComment-14457326
Generating grub configuration file ...
Found theme: /usr/share/grub/themes/garuda/theme.txt
Found linux image: /boot/vmlinuz-linux-tkg-bmq
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-tkg-bmq.img
Found fallback initrd image(s) in /boot: initramfs-linux-tkg-bmq-fallback.img
Detecting snapshots ...
Info: Separate boot partition not detected
Found snapshot: 2021-02-05 09:06:19 | timeshift-btrfs/snapshots/2021-02-05_09-06-19/@
Found snapshot: 2021-02-04 19:55:54 | timeshift-btrfs/snapshots/2021-02-04_19-55-54/@
Found snapshot: 2021-02-04 18:50:58 | timeshift-btrfs/snapshots/2021-02-04_18-50-58/@
Found snapshot: 2021-02-04 18:42:36 | timeshift-btrfs/snapshots/2021-02-04_18-42-36/@
Found snapshot: 2021-02-04 18:31:03 | timeshift-btrfs/snapshots/2021-02-04_18-31-03/@
Found snapshot: 2021-02-04 15:37:06 | timeshift-btrfs/snapshots/2021-02-04_15-37-06/@
Found 6 snapshot(s)
Found memtest86+ image: /boot/memtest86+/memtest.bin
done
I got this after running commands given by you
https://linustechtips.com/topic/1302308-grub-menu-problem/#findComment-14457327
I managed to mount those drives..
after running the command I got
https://linustechtips.com/topic/1302308-grub-menu-problem/#findComment-14457336
You need to install ntfs-3g with
sudo pacman -S ntfs-3g
And are you sure you had them all successfully mounted when you ran grub-mkconfig? Because what you should get is something like this, note "Found Windows Boot Manager" on there:
33 minutes ago, TorC said:
ntfs-3g  is the first thing to make sure is installed.
Garuda is Arch-based?  Devs were negligent, IMHO.
2021-02-05 20-34-44.mkv
Update: I uninstalled the KDE version of Garuda and installed GNOME version of Garuda
now when I ran
I got this error
https://linustechtips.com/topic/1302308-grub-menu-problem/#findComment-14458283
9 minutes ago, gardotd426 said:
You already have os-prober, then. Garuda apparently uses a forked grub with a forked os-prober.
Just out of curiosity, what's the output of
efibootmgr
Literally didn't understood the first line
but is there any fix for this?
or crying is the only last option?
https://linustechtips.com/topic/1302308-grub-menu-problem/#findComment-14458586
1 minute ago, gardotd426 said:
I mean you only need one entry, mine has two for a different reason, but yeah efibootmgr should show all EFI bootloaders on the system (and doesn't use os-prober), and yours isn't showing Windows.
So If I install this OS without UEFI
it will work right?
https://linustechtips.com/topic/1302308-grub-menu-problem/#findComment-14458598
No, you need to be using UEFI. Windows isn't using UEFI, and it needs to be. You would need to reinstall Windows and use UEFI.
Or, you could install refind and use refind instead of grub as your bootloader, and see if that detects Windows. If it doesn't then you're definitely not using UEFI for Windows.
https://linustechtips.com/topic/1302308-grub-menu-problem/#findComment-14458601
