Budget? Motherboard size? What will be the specs? any preferences? also you might mean RGB fans in a case with window panel and preferably mesh front
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1301479-rgb-case/#findComment-14448683
I can't really say I've seen a good RGB case I actually like. The majority of them out there have really bad thermals or I just don't like the look of them. It really comes down to your preference. There are RGB lighting accessories I like and would use to light up the case.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
https://linustechtips.com/topic/1301479-rgb-case/#findComment-14449959
