Is this really a big issue? Its most likely windows just initializing the Ethernet driver and connecting to the internet. I don't see how it taking half a minute to connect to Ethernet after booting up is a bad thing... sure it might be a little over normal. What MOBO do you have ? Do you have the manufacturer driver installed for the Ethernet?
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1301463-help-please/#findComment-14448590
I have a gigabyte z390 ud mobo. If it did it from the beginning I wouldn’t mind but it just started recently
https://linustechtips.com/topic/1301463-help-please/#findComment-14448680
