Possible?
Given a router/endmill, CAD, and some time dedication on your part: yes.
Commercially available, RAM, M.2 and HDD/SSD blocks have not been widely successful. They've been tried (most, if not all multiple times), and fail because of their very limited return on investment. I do not know of any monitor watercooling.
https://www.aquatuning.us/water-cooling/hdd-ram-cooler/
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/1301442-water-cooling/#findComment-14448416
Almost everything in the pc itself can be cooled. The monitor would take some wowed, unless you meant motherboard.
But certain boards already have blocks made to cool the other components.
Some can accept universal blocks but that’s takes some research.
Same with ram, m.2 and Hdds. Just gotta order the parts and do it. Pretty simple overall.
https://linustechtips.com/topic/1301442-water-cooling/#findComment-14452883
Possible? Yes. Available? Yes. Does it give you any benefits? No.
M.2 Controllers like it cold yet the chips like it hotter, SATA SSDs have a package that basically shields them from most of the outside, HDDs can benefit from it but you basically don't use those anymore and cooling system memory doesn't give you any benefits. The best thing you could cool except for CPU and GPU are the chipset and the VRMs. The rest is just for the show.
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/1301442-water-cooling/#findComment-14453637
