Hey guys do you have any recommendations for a case???
CPU: i7 10700k
GPU: RTX 3060ti
Motherboard: MSI MPG Z490 GAMING EDGE WIFI ATX
Cooler 1: be quite Dark rock pro 4
Power Supply: Corsair 750w Power Supply 80+
Ram: Corsair Vengeance RGB PRO 16GB
Storage: WD_Black SN750 1TB NVMe Internal Gaming SSD
https://linustechtips.com/topic/1301233-please-help/
CPU: i7 10700k
GPU: RTX 3060ti
did you decide against the phanteks p400?
https://linustechtips.com/topic/1301233-please-help/#findComment-14446819
2 minutes ago, Almighty Potato said:
budget is 150 ig
well for a 150 you can get almost anything, airflow is important so that's the only thing i'd keep in mind next to aesthetics. ah also look for a mid tower for that board. tbh i'd get an nzxt h510 elite even tho it's airflow is shite
https://linustechtips.com/topic/1301233-please-help/#findComment-14446831
Not exactly against it, I was looking at the Cooler Master MasterBox TD500 Mesh Airflow ATX Mid-Tower, but I read a lot of negative reviews about it breaking and the fans dying so, yah.
https://linustechtips.com/topic/1301233-please-help/#findComment-14446832
try this one it's fairly new but it seems like it's a good option, the only downside is that it comes with a mere 2 fans
https://linustechtips.com/topic/1301233-please-help/#findComment-14446839
Get a Phanteks P400a or a P500a if you want something a little bigger. It's a great case that's super easy to build in (I built a system in 2 hours with no prep in one of those, they're dead simple). I'd recommend the 400 over the 500, but either is good and would be a great match for your system, and if you want to spend the full $150 on it, get the non digital version and buy a bunch of aftermarket fans (either be quiet! or Noctua for the best performance).
https://linustechtips.com/topic/1301233-please-help/#findComment-14446840
Thx man, i decided on the p400a, one question, are the fans good and how many are there? Also for my first time how long do you think it will take to actually build it?
https://linustechtips.com/topic/1301233-please-help/#findComment-14446942
also you have exactly 420 posts, lol
https://linustechtips.com/topic/1301233-please-help/#findComment-14446943
The p400a comes with 2 mediocre fans unless you get the RGB edition, then it comes with 3 mediocre fans. It's recommended to swap them out for better ones, and more of them. Get the non-digital one, it's about $70, so you have $80 to get a bunch of fans/
https://linustechtips.com/topic/1301233-please-help/#findComment-14446979
just to be sure you mean this one right, https://www.amazon.com/gp/product/B01N9JPSEU/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
https://linustechtips.com/topic/1301233-please-help/#findComment-14447268
2 minutes ago, RONOTHAN## said:
oof will the other one work, it also has really good reviews
https://linustechtips.com/topic/1301233-please-help/#findComment-14447280
4 minutes ago, RONOTHAN## said:
it is just a replacement panel for the p400, that is what mean right?
https://linustechtips.com/topic/1301233-please-help/#findComment-14447285
it's just a different panel, but I don't think they sell it independently. It comes in and out of stock pretty regularly, give it a week and it'll be in stock. It's the difference between bad airflow and great airflow
https://linustechtips.com/topic/1301233-please-help/#findComment-14447295
ok so just to be clear, i should get the p400 with this panel, right?
https://linustechtips.com/topic/1301233-please-help/#findComment-14447298
https://www.amazon.com/Phanteks-Mid-Tower-PH-EC400ATG_DBK01-Tempered-Digital-RGB/dp/B07TTDW9KV/ref=sr_1_1?dchild=1&keywords=p400a&qid=1612224131&s=electronics&sr=1-1
Just realized the RGB version is in stock. I'd personally say wait and get the non-RGB version and get some aftermarket fans, but if you don't want to wait it's only $15
https://linustechtips.com/topic/1301233-please-help/#findComment-14447308
ok thx man
https://linustechtips.com/topic/1301233-please-help/#findComment-14447328
yo yo is this the one, https://www.amazon.com/gp/product/B07TYR1P1G/ref=ox_sc_saved_title_1?smid=A284PRV19Y1MTF&psc=1
https://linustechtips.com/topic/1301233-please-help/#findComment-14453389
