5800X thermal throttling on full load.
Solved by mr cheese,
If you'd like to stay air-cooled, NH-D15 would work great for you. If you like water, the LiquidFreezer 240 would work great as well. The weird temperature distribution makes me think you may need to fix your thermal paste or your mounting (there is a process to tightening those screws), so I would check that.
AngelaHornung ·
NeuronButter ·
Posted in Troubleshooting0 -
3
4
Bactraxed ·
Posted in New Builds and Planning1 -
jkb ·
Posted in Troubleshooting1 -
2
NobleGamer ·
Posted in Troubleshooting2
