Budget (including currency): $900
Country: USA
Games, programs or workloads that it will be used for: cs, valorant and streaming
Other details I need someone to check this listing > https://www.ebay.com/itm/REFURBISHED-MSI-GeForce-GTX-1650-SUPER-GAMING-X-BV-Graphics-Card-PCI-E-x16/324448357924?epid=22037905095&hash=item4b8aa10e24:g:zyoAAOSwfmFf-z-a#viTabs_0 and tell me whether I should jump on getting this or not.
Here is my pcp list with the gpu already in:
PCPartPicker Part List: https://pcpartpicker.com/list/YcYGwz
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($194.99 @ Newegg)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($124.99 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($76.99 @ Newegg)
Storage: Samsung 860 Evo 500 GB 2.5" Solid State Drive  ($56.99 @ Adorama)
Video Card: MSI GeForce GTX 1650 SUPER 4 GB GAMING X Video Card  ($247.99)
Power Supply: SeaSonic FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($96.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($108.78 @ Other World Computing)
Total: $907.71
Generated by PCPartPicker 2021-01-31 15:52 EST-0500
List was made by SpiderMan
As I said I need serious answers asap
https://linustechtips.com/topic/1300835-i-need-help-asap/
Should I jump on this ebay listing? https://www.ebay.com/itm/REFURBISHED-MSI-GeForce-GTX-1650-SUPER-GAMING-X-BV-Graphics-Card-PCI-E-x16/324448357924?epid=22037905095&hash=item4b8aa10e24:g:zyoAAOSwfmFf-z-a#viTabs_0
here's my pcp build by SpiderMan
Total: $907.71
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443629
I would never pay double the original MSRP for a used/refurbished card, sorry but that's a horrible deal.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443638
Country: USA
Total: $907.71
looks fine, but that GPU is WAYYYYYYYYYYYYYYYYY over MSRP, MSRP for new is ~$180 and MSRP for used is under $150. If you are ok with that then it looks fine.
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443641
Would it be good for longevity tho? Like this was one of the lowest prices for nvidia cars that wasn't under 1080
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443648
I get that its a "scalpped" price but it's better than paying $1k for a 3060 right? and I could upgrade to a 3060 in the future right?
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443654
If I had to guess it's leftover mining stock being resold. I wouldn't touch it at that price even if it was brand new in box.
Prior Build Log/PC:
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443656
$109 for windows is a scam. Did you build the rest of the PC already and are just trying to get a GPU?
SPEC LIST:
  • CPU: AMD Ryzen 9 5950X w/ NZXT Kraken Z73 360mm Liquid Cooler
  • GPU: NVIDIA RTX 3090 FE
  • RAM: Corsair Vengeance LPX 32GB (4 x 8GB) 5000MHz CL18
  • Motherboard: MSI MEG X570 Godlike
  • SSD: Samsung 980 Pro PCIe 4.0 1TB (x3)
  • PSU: Corsair AX1600i
  • Case: NZXT H710
  • Monitor: Alienware AW2521H 25inch 360Hz 1ms
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443660
-= Topics Merged =-
Please do not multi-post your topics.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443661
aight i'll consider it
There are GTX 1070s going for lower than that price which are better performers.
Prior Build Log/PC:
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443665
Prior Build Log/PC:
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443672
haha, sure. You can upgrade to a 3060. But if you really commit, you CAN get a 3060. It took me ~5 days to get one at MSRP from bestbuy.
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443688
ok, so i'll get the 1070ti first then upgrade to the 3060 hopefully
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443690
sounds good.
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443694
4 minutes ago, MarvintheParrot said:
sounds good.
another question: in my build "Operating System: Microsoft Windows 10 Home OEM 64-bit  ($108.78 @ Other World Computing)" is there any other place I can get that for cheaper than $108 or get a unactivated version of windows then pay later
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443710
Yes, you can. You can get it around $20-$30 from Key resellers.
Here is a video!
https://linustechtips.com/topic/1300835-i-need-help-asap/#findComment-14443725
