Hey guys I currently have an i5 2500k and therefore in order to upgrade to a new platform I would need to buy a new cpu, motherboard and Ram. While I will be doing this later down the road I was wondering if I were to pick up a i7 2700k (I can get one really cheap) would this improve my gaming performance at all in modern titles? I thinking maybe while it is still 4 cores maybe the 8 threads compared to 4 might improve performance on newer titles that make use of higher core cpus.
Any help would be appreciated thank you
https://linustechtips.com/topic/1300555-need-help-on-upgrading-my-cpu-please/
It will depend on the game.
It will in some.... and with some others, it will be EXACTLY the same as a i5-2500K.
Some due to "slower" IPC of the Sandy Bridge architecture, and some due to 4-cores just not being enough (regardless of the number of threads).
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
You'll see the most bang for your buck from a new video card, even a used GTX 970 for sub $100(if those didn't double in value) would be a solid upgrade from a 660ti. The sub $200 market is beyond broken though so I'd honestly only suggest buying used right now like a 1060/1070 if you can find them for a decent price.
Entirely depends on the games you want to play though where your money would be best spent.
Honestly I wouldn't bother. The modern difference between those two CPU's is minimal.
The i5-2500k has a pass mark of 4,090
The i7-2700k has a pass mark of 5,607
To put this in perspective a Ryzen 3 - 3300X (which competes again the i3's) has a pass mark of 12,777.
Outside of old games that is not really going to give you any noticeable performance bump in modern titles.
