Cpu and its compatible memory speed confused
Go to solution Solved by Helpful Tech Witch,
On a h or b (Intel) series chipset, the cpu memory support will be what you can run at.
Budget (including currency): NA
Country: Australia
Games, programs or workloads that it will be used for: NA
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): So pretty much I was going to buy The intel core Intel core i3 9100f cpu for my build https://au.pcpartpicker.com/user/CustomPcbuilder321/saved/#view=ZbPtnQ   (which will be for me to late sell) and then I am getting the
Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL15 Memory
aswell, yet I checked the cpu page and said it supports memory of DDR4 2400 mhz yet I am getting 3200mhz So do I have to change the ram?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
