Budget (including currency): 4000 USD
Country: Switzerland
Games, programs or workloads that it will be used for: Games
Hi All,
I have a quick question as I am finishing my build and when I was looking to plug in the PCI-e cables into the GPU they seem to have different connector shapes. I checked and this is the case for both the PSU cables as well as for the Cable Mods that I bought. Basically from the picture I see the following:
PCI-e cable shapes:
Top Row: Notch Notch Square Square
Bottom Row: Square Notch Notch Notch
GPU connector shapes:
Top Row: Square Square Notch Notch
Bottom Row: Notch Notch Notch Square
To be honest I'm also a bit afraid to force the cables in as this was quite an expensive GPU and wouldn't want to damage anything. What do you think? Is this normal?
Kind regards,
Eddy
https://linustechtips.com/topic/1299994-pci-e-cables-fit/
4 minutes ago, eddykalex said:
PCI-e cable shapes:
Kind regards,
Eddy
When you turn it around to plug it in, it will fit fine.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1299994-pci-e-cables-fit/#findComment-14436940
Cable mod replacement cables have two sides, one that goes into your PSU the other that goes into your videocard. Are you sure you're looking at the right end?
https://linustechtips.com/topic/1299994-pci-e-cables-fit/#findComment-14436954
Yes I'm positive, the other end that goes into the PSU cable wouldn't even have the external connectors to go into the PSU. See picture with the other end as well.
https://linustechtips.com/topic/1299994-pci-e-cables-fit/#findComment-14436960
Just now, eddykalex said:
The PSU cable is 6+2 and it says PCI-e on it whereas the Cable mod has full 8-pin
if it says so then it should be right
the fit should be tight but not SO tight that you have to push like you're giving birth
some friction is normal and fine
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1299994-pci-e-cables-fit/#findComment-14436971
one more way to know it's a pcie 8-pin is to look for this bridge, two pins should have plastic connecting them, corresponding to this hole
image.png.45acbfb1fb68e8a66490199543ef18af.png the picture of your cable is too blur for me to be sure
https://linustechtips.com/topic/1299994-pci-e-cables-fit/#findComment-14436977
The PSU cable is definitely PCI-e as it says so on the cable itself and it does have the bridge that connects those 2 pins (being a 6+2 format) but the cable mod has full 8 pins. Nonetheless, both the end of the Cable mod and the PSU cable that should go into the GPU have the same structure which somehow is different then those shapes on the GPU connectors.
https://linustechtips.com/topic/1299994-pci-e-cables-fit/#findComment-14436987
i think the shape doesnt match...? dont quote me on that
but if it says it's PCIE then it should be fine
and
https://linustechtips.com/topic/1299994-pci-e-cables-fit/#findComment-14436992
ah okay, they are cablemod extension cables. yeah, those don't go into the PSU.
Looking a bit closer at your pictures, I'm unsure what the issue then is.
it's a bit low res, because of the left pic being a bit low res, but it seems to match fine, does it not?
https://linustechtips.com/topic/1299994-pci-e-cables-fit/#findComment-14436993
OMG I feel so dumb, you are right, I needed to check the opposite sides. Thank you so much and apologies for my stupidity
https://linustechtips.com/topic/1299994-pci-e-cables-fit/#findComment-14437002
happens to be the best 😅
always better to doublecheck when in doubt!
https://linustechtips.com/topic/1299994-pci-e-cables-fit/#findComment-14437013
