Need help upgrading
Go to solution Solved by flashiling,
1 minute ago, Don Loong II said:
It doesnt stay the power draw on the package it came with
does this mean you don't know how much W your psu has?
if you're talking about your storage device, then it usually doesn't say the power draw since it's not very much.
so you should have no issues using it in your pc
not sure how much I trust that PSU buuuuut to answer your question yes it'll be more than enough
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14435779
usually your storage devices aren't drawing an insane amount of power, so unless you're already doing daily coinflips with whether or not you get enough power to your system then i don't think you'll have issues
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14435828
wut?
the only issue you might have is the right power cables.
But that might not be the issue, only the version of the PSU might be. Else so long you have an PSU with the common power cable for that SSD/HDD and SATA cable (SSD not HDD?). It should "just work", also you already have some storage and there shouldn't be much reason as for why you can't add more. If you had more GPU and CPU power draw or more plugged into the system, then it could be worse, but storage is not the first thing to really care about.
If the PSU is not up to the task, that would be more of a concern and if it would be a fire hazard or destroy some components.
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14435851
1 hour ago, Quackers101 said:
wut?
U made me confused, i wanna upgrade my storage cuz i need space for some files
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14435964
Wdym coinflips?
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14435966
Wdym coinflips?
it was just something i made up to try and explain that if your current system uses 495W (just an example i don't know what your system uses) and you want to add a new drive that might use 10w more, then you'd be going over the 500W limit on your psu (again just using the 500W psu as an example), which isn't good.
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14435971
How do i calculate how many watts my pc uses?
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14436028
you look at the powerdraw of the individual components and add them up.
but if your current build is the same as what you've written on your profile system then you should have absolutely no issues.
650W is more than enough for your system
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14436032
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14436038
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14436042
Okok ty, ive been debating with myself if the psu will blow up. Anyways thanks!
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14436048
Hey, i was gonna open my case then i got a small amount of electric shock thats kinda constant. Its at the tips of my fingers, what do i do?
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14436086
first of DO NOT TOUCH your computer parts right now.
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14436089
you seem to be charged and you risk shocking your components and destroying them.
Get a esd wrist band and make sure it's grounded.
if you don't have one here's a few ways you can do it.
also make sure that your psu is also turned off (flip the switch to 0) when touching the components inside your computer. (personally i also remove the power cable, people say it's not nessecary but i just do it to be certain that it's off).
https://www.ifixit.com/Answers/View/186888/How+do+I+ground+myself
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14436103
I dont have an esd wrist band and cant buy one rn cuz my parents dont have their salary yet. But i have a voltage tester that has a ground and a red wire (i forgot the name)
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14436109
did you check the link i sent you with other ways of achieving similar effects?
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14436112
Reach over and touch the center screw of a wall electrical outlet, if the house is wired with a ground. Touching a radiator or gas pipe will also work. But do this every time you sit down as walking around on most carpets will generate a charge.
https://www.wikihow.com/Ground-Yourself
another way to do it.
personally i don't know how those work so i can't say how to use it 😄
https://linustechtips.com/topic/1299844-need-help-upgrading/#findComment-14436133
