Hello guys!
I am a relatively new PC builder and recently decided to upgrade from my current build and build a new more beefy one.
I am currently running:
AMD Ryzen 9 5950x (stock)
Zotac Gaming Trinity RTX 3090 (stock)
ROG Crosshair VIII Hero Wifi
64gb Gskill Trident Z Neo 3200mhz
Sabrent 2TB Rocket Q4 NVMe PCIe 4.0 M.2 2280
A 6tb 5400rpm WD Blue HDD
Seasonic Focus-PX 850w 80+ Platinum PSU
Ive also got a h100i elite capellix 240mm AIO cooling the cpu, and its in a corsair 4000x case.
Ever since booting into windows, I have been plagued by seemingly random BSOD all with the same error.  Attached are examples of the messages received.
I have tried wiping the drives and reinstalling windows, re-seating my hardware minus the cpu, to no avail.  Sometimes it works for 5 minutes and BSOD, sometimes it works for 8 hours and BSOD.
Please help!
(I have also run the CHKDSK and come back with zero issues)
On Thu 1/28/2021 8:44:30 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: ntfs.sys (Ntfs+0x11527E)
Bugcheck code: 0x124 (0x0, 0xFFFFCD08251E4028, 0xBC800800, 0x60C0859)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\drivers\ntfs.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT File System Driver
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem.
The crash took place in a file system driver. Since there is no other responsible driver detected, this could be pointing to a malfunctioning drive or corrupted disk. It's suggested that you run CHKDSK.
crash dump file: C:\Windows\Minidump\012821-10296-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F5780)
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
https://linustechtips.com/topic/1299829-bsod-with-seemingly-no-fix/
It could mean your primary drive may have issue. Try to check the connection of your primary storage device. Power off your PC and reseat your M2 SSD or unplug and re-plug SATA power and data cable.
Also, if possible, run this command:
sfc /scannow
to check if your Windows has issue.
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
