This would be a short burst of processing, probably from loading. Don’t know why a low temp under load seems to concern you, perfectly normal for short term bursts to have lower temps depending on the architecture and cooling system
edit: to clarify I mean the cpu unpacking textures etc and loading things into memory for quick access of the program you just started
