My bad if this is in the wrong spot, but would anyone be able to tell me what case this is?( pardon my obviousness in the text overlays)
Edit: the front of the case that holds the led strip/metal grate swings forward to the left as you look at it. Access to the floppy/optical bays is behind it.
https://linustechtips.com/topic/1298519-case-identification-help/
  • 1 month later...
Thrasher, im going to have to call that the exact case, cause the only difference is the emblem on the front(the 'x' if you will) which, tbh, comes of really easy. having a missing fan grill makes sense on the side as well. ty for the input, and sry for the late reply.
26 minutes ago, tkitch said:
That build style was very popular in the earlier 00's.  That was pretty standard, and it's probably a cheap case overall.
No cable management.
Even expensive cases in the early 00's didn't really have cable management.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
that why there was cable origami. the art of hiding that shit!
