What country, and budget? typically I would just recommend the best motherboard for the available budget.
However, let's get some additional info. Do you need any specific features? What is your planned upgrade path? Any size limits?
Also please change your topic title to something like "motherboard advice," add some description of what you actually need.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1298269-guys-i-need-some-help/#findComment-14423653
My busget is 30k(INR) I am thinking of buying Gigabyte B450
https://linustechtips.com/topic/1298269-guys-i-need-some-help/#findComment-14423667
Gigabyte makes a lot of B450 motherboards, but there may be some better options for a 3200G. 30,000 INR is X570 territory with some really nice motherboard options, but even something like this would be good:
https://in.pcpartpicker.com/product/BHBhP6/msi-b450-gaming-plus-max-atx-am4-motherboard-b450-gaming-plus-max
lots of connectivity and decent overclocking capabilities, even for an 8 core CPU.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1298269-guys-i-need-some-help/#findComment-14423672
I would like to buy B450 for saving many ?
https://linustechtips.com/topic/1298269-guys-i-need-some-help/#findComment-14423676
then I recommend the motherboard I linked above, or similar boards in the B450 "MAX" line from MSI. They are guaranteed compatible with 3000 series Ryzen processors.
1 minute ago, RAM555789 said:
I would go for a B550 if your trying to future proof. At the very least you'll be able to upgrade to Ryzen 50XX in the future, possibly even further depending on how long the chipset lasts.
B550 unfortunately isn't compatible with 3200G and 3400G processors (some are but you'd have to check the compatibility notes of specific boards)
Primary PC:
PSU tier list
https://linustechtips.com/topic/1298269-guys-i-need-some-help/#findComment-14423679
