failure to load "swap /swapfile" error after "/etc/fstab/" edit for NTFS steam games
Solved by William Briot,
Here's a basic fstab for reference :
# /etc/fstab: static file system information. # # Use 'blkid' to print the universally unique identifier for a # device; this may be used with UUID= as a more robust way to name devices # that works even if disks are added and removed. See fstab(5). # # <file system> <mount point> <type> <options> <dump> <pass> # / was on /dev/sde1 during installation UUID=1612f07a-04c3-4015-88f0-7aa10eed4e2b / ext4 errors=remount-ro 0 1 # swap was on /dev/sde5 during installation UUID=8f45bef7-0848-43b6-8c3b-a444cf35606b none swap sw 0 0
You should have an entry which mount point is /, but that's not the case in your fstab.
If / doesn't exist, then the system cannot find /swapfile.
There should be a line directly below the " # / was on /dev/nvme0n1p1 during installation "
Run
ls -lha /dev/disk/by-uuid
and check which uuid point to /dev/nvme0n1p1
Then add :
UUID=<The uuid you just got> / ext4 errors=remount-ro 0 1
To your /etc/fstab (below the comment I mentionned above is good)
