On 1/20/2021 at 12:02 PM, Aakash_Ram said:
Hi I know this is prob a dumb question but I need any way to get a 5900x within 100 usb of retail price. I do not want any scam websites only known ones. Any help would be appreciated thank you.
Do you live close to a microcenter or best buy? If so join their unofficial discord and keep an eye on them to see when things will drop. I got a 5909x and a 3080 plus everything for a full build a my local microcentrr over a week period. They got in probably 150-200 30xx gpus and 100-125 5600-5950x cpus.
There is also Newegg new lottery system.
https://linustechtips.com/topic/1296273-help-with-5900x/#findComment-14413703
what is the lottery system. I Do live near Best Buy also for Best Buy it says online only on their website
https://linustechtips.com/topic/1296273-help-with-5900x/#findComment-14419703
With newegg when they have inventory come in you can go signup to buy it. Then after 4-6 hours they do a drawing basically to randomly select those that will get their GPU/CPU. It was done to help against bots and give everyone a "more fair" chance according to them.
https://linustechtips.com/topic/1296273-help-with-5900x/#findComment-14420398
