Hi i have this weird problem couple of months now.i upgraded my pc year ago everything was fine until september or october.i ussualy play fortnite competitively and have this weird problem pretty much my mouse movemernt randomly feels sluggish/delayed its like less responsive mouse pretty much feels off,like its not smooth.slowin down randomly i can tell everytime this happens because fortnite is battle royale game where i build and its noticable even my little brother notices it.this problem started like 5-6 months ago maybe i think i messed up some settings or something i dont know this happens only in game dekstop is fine.also lowering resolution in game config from 1920x1080(native) to 1024x768 helps a little bit it reduces floaty mouse feel but not fixes it for 100%.i have mouse acceleration off,vsync off, i tryied reinstalling gpu drivers.reseted windows in settings to factory but still not luck
My specs:gtx750 ti
8gb ram
Intel core i7 3770
Game runs at constant 120 fps
https://linustechtips.com/topic/1296200-help-me-input-delay/
My specs:gtx750 ti
8gb ram
Intel core i7 3770
Find an old PS2 mouse and try it
https://linustechtips.com/topic/1296200-help-me-input-delay/#findComment-14409067
52 minutes ago, saqu. said:
Im pretty sure its not mouse fault i tryied with 2 different mouses
There is a reason I am telling you this try an old PS2 mouse instead or USB.  When the PC is taxed playing a game the USB lags with it while the old PS2 is more reliable and does NOT lag.
If you want reliability and minimum lag you game on a PS2 mouse. I figured this out years ago.
https://linustechtips.com/topic/1296200-help-me-input-delay/#findComment-14409352
