First PC build ram or motherboard issue
e0325
Hey everyone,
I helped my son with his first pc build
specs
MSI B450 Tomahawk
Team T-Force Delta 16gb DDR-4 2x8gb
Rayzen 5 3600
MSI gtx 1660 super
EVGA BQ 600 w
We installed the ram in slots 2 and 4 per the diagram on the motherboard.  When both sticks are installed the DRAM light on the motherboard stay's lit and the pc wont turn on or post.  If i remove the stick located in slot 4 the pc boots fine, i have tried to swap the stick around and it didn't matter.  I can put either stick into slot 2 and the pc is fine
Things i have done
Updated the BIOS
re seated the memory (numerous times)
re seated cpu
Any help would be greatly appreciated
Bad MOBO Most likely
Try a new one if you can!
If you still have a warranty take it back and get a new one.
(Could be the CPU though)
(I'm assuming you made sure each ram stick works)
Most MOBO companies are pretty good about faulty units.
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
I agree that this is most likely a motherboard problem, but for the sake of being thorough, try a single stick of RAM in every slot and report back the results.
Also try a stick in slots 1 & 3. The results of this can be useful for troubleshooting purposes even if it is not a recommended configuration.
BabyBlu (Primary):
  • CPU: Intel Core i9 9900K @ up to 5.3GHz, 5.0GHz all-core, delidded
  • Motherboard: Asus Maximus XI Hero
  • RAM: G.Skill Trident Z RGB 4x8GB DDR4-3200 @ 4000MHz 16-18-18-34
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2070MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 10 Pro
Roxanne (Wife Build):
  • CPU: Intel Core i7 4790K @ up to 5.0GHz, 4.8Ghz all-core, relidded w/ LM
  • Motherboard: Asus Z97A
  • RAM: G.Skill Sniper 4x8GB DDR3-2400 @ 10-12-12-24
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Corsair Vengeance C70, w/ Custom Side-Panel Window
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair AX760
  • Display: Samsung C27JG56 27" 2560x1440 144Hz Freesync
  • Cooling: Corsair H115i RGB
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Thanks for the replys
Single RAM test
slot 1 - message ram was in the wrong slot but it still booted
slot 2 - booted fine
slot 3 - DRAM light no boot
slot 4 - DRAM light no boot
I have another question
If the MOBO is bad, which seems likely. Should I
1. Reach out to B&H where it was purchased on 1-9-2021, my son threw away the anti static bag and inside cardboard piece.  I do have original box and paper work
2. Reach directly to MSI for a replacement
Single RAM test
Hmmm. That's not super conclusive. Either your mobo has two bad dimm slots, or your CPU IMC's channel B is bad. It's still most likely the motherboard, so you should do this:
As long as you are still in the returns window, this is always the easier and faster method. Let the retailer deal with MSI for you. 🙂
When you get the new motherboard, if the problem persists, then you'll have to look into replacing the CPU, but hopefully it's the motherboard at issue.
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
