I need help with RGB
Eivw
Hello!
I want to buy RGB fans for my pc. And i want to know if i can daisy chain them to my pc case (Phanteks eclipse p350x) since i don’t have a RGB connection on my mobo. And the Lighting modes are good enough for me! My case has a male D-RGB fan connector and a female M/B D-RGB connector. So the question is Can i do it and What fans should i get?
  • 4 weeks later...
I just checked out the product page on Newegg:
"Preprogrammed with the best selection of color modes and patterns and requires no setup or software."
From what I gather, you're case lights up properly with Phanteks built in DRGB controller. Sounds to me like you're good to go with daisy chaining your choice of fans. I'm not well versed in RGB Fans, but I would make sure they utilize the same D-RGB standard for the lighting effect.
