Hello everyone.
Please, I would like your help to the following.
I have a POS terminal Ingenico iCT220 which I want to connect it to the router.
Having a networking cat5e cable, I would like to make the two edges of the cable with connectors. I do not know the pinouts (or colors) on each edge.
Does anyone know the two edges pins (or colors)
Thank you for your ti!
https://linustechtips.com/topic/1295710-cable-making/
I guess you mean cable like that:
So, the ethernet port on Ingenico iCT220 is not for making it work via internet.
Please, have a look at small video here:
My big wonder, as you will see on video, that it has not internet port. I mean, to connect it to a router port, and make it work via internet and not telephone line. But, if no internet working, why it has DHCP or manually IP setup on its menu? What is it for?
Telephoning to company that sells iCT220 told me that it works with internet too. Not only with telephone line.
https://linustechtips.com/topic/1295710-cable-making/#findComment-14405270
It has an ip so that you can telnet into it and configure it would be my guess.
https://linustechtips.com/topic/1295710-cable-making/#findComment-14405774
