Blower card fan replacement.
Go to solution Solved by Ashleyyyy,
3 hours ago, TrigrH said:
take the shroud off and ziptie a case fan to the heatsink.
basically this, or see if you can find a dead card with the same cooler as yours and see if you can take the fan from that and put it on your card.
I have a GeForce GTX 960 2GD5 and its fan was rather loud for quite a bit, but now it started emitting a clicking/rattling noise. (And im 100% sure its the cards fan)
Was wondering if there are Blower Fans i could replace the existing one with.
I wasnt able to find any Blower Fan listings in any of my local stores, only Aliexpress
Could anyone please point out one that would be able to replace the one i have now with?
CPU:6600K | MB:Z170A PC MATE | RAM:Kingston HyperX Fury Black 24GB 2666MHz CL16 | GPU:ASUS TUF 3060Ti  | Case:Aerocool Strike-X One | Storage: 970 EVO 1TB | 870 QVO 1TB |Toshiba DT01ACA100 1TB | Seagate Barracuda 2TB (18k+ Real. Sectors) | PSU: MSI MPG A850GF 850W | Display: Asus TUF VG249Q1A | Dell SE2416H | Cooling: Liquid Freezer II 120mm
https://linustechtips.com/topic/1295525-blower-card-fan-replacement/
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
