I would honestly just keep the Pure Wings 2. I have a couple of them in my case (silent base 800) as case fans and they do the job fine.
Is there a problem that is making you want to change, or do you just want to upgrade to something better?
Edited by Spotty
https://linustechtips.com/topic/1294953-case-fan-question/#findComment-14399645
Upgrade Something better and my case is white
https://linustechtips.com/topic/1294953-case-fan-question/#findComment-14399664
