So I just got done building my first computer in yeaaaars and I'm not sure what I'm doing wrong. I bought ddr 4 3200 memory but it's running I believe it was 2400 (not in front of it at the moment) not sure how to fix it tried changing the clock speed to 3200 in the bios but then it just wouldn't boot. Here are my specs
ASUS ROG Strix B550-F
PNY 16GB XLR8 Gaming DDR4 3200MHz
Ryzen 5 5600x
Apevia ATX-PR800W Prestige 800W 80+ Gold
As for gpu it's just a basic one to get some outputs
https://linustechtips.com/topic/1294444-memory-wont-run-at-full-speed/
Did you use an xmp profile to set the speed or did you do it manually? Try xmp
SPEC LIST:
  • CPU: AMD Ryzen 9 5950X w/ NZXT Kraken Z73 360mm Liquid Cooler
  • GPU: NVIDIA RTX 3090 FE
  • RAM: Corsair Vengeance LPX 32GB (4 x 8GB) 5000MHz CL18
  • Motherboard: MSI MEG X570 Godlike
  • SSD: Samsung 980 Pro PCIe 4.0 1TB (x3)
  • PSU: Corsair AX1600i
  • Case: NZXT H710
  • Monitor: Alienware AW2521H 25inch 360Hz 1ms
