Installed new parts, PC doesn’t display anything
Solved by Radium_Angel,
1 minute ago, G_E said:Plugged in with hdmi on motherboard. Monitor Is working and on right input, lights on keyboard do not light up. Motherboard was open box.
Open box...ok, so two options:
(1) The BIOS is old and doesn't support the CPU, as @Bartholomew97 suggested
(2) the mobo is bad
Now, *some* mobos allow you to flash the BIOS to the latest version without having the CPU installed, but you'll have to read your manual to see if this is possible.
