Aorus B450 question!!
The pro seems to have USB-C while the elite doesn't.
The pro has an Intel® GbE LAN with cFosSpeed while the Elite has a GIGABYTE Gaming LAN with Bandwidth Management.
They both have RGB Fusion 2.0
The pro has SPDIF while the elite doesn't.
The back I/O is different on the boards.
With the Pro version you'll get:
1 HDMI Port
1 USB 3.1 Gen 2 Type-A port
4 USB 3.1 Gen 1 ports
1 DVI-D Port
1 USB-C Port
2 SMA Antenna Connectors (this is only found on the WI-FI version)
With the elite you'll get:
1 PS/2 connector
1 DVI-D connector
1 HDMI connector
4 USB 3.0 connectors
That's all I could find for differences. It all comes down to what you want, what you'll do and which board will fit within your budget.
