Hey guys. I just got a new graphic card so i got the Corsair 750M power supply. When i replaced the power supply and started the pc i got an overvoltage problem. I see lots of people saying its usually the motherboard but can you take a look and see? Motherboard is Asus Prime A320M-K
Processor: R5 1600x
Graphics: KFA2 3070
Thanks in advance
https://linustechtips.com/topic/1293038-over-voltage-error-help/
Holy Shit. I am 90% sure that the board is reporting wrong. Try the old PSU again and see if it says stupidly high voltages.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
I cant. The old PSU is 550w and the 3070 needs 650w. Should i get a new motherboard or?
They're asking that you try it. If you're not doing anything with the GPU it'll be just fine with a 550W psu, the 650W is a recommendation, I ran a 5900X and 3060ti at full blast on 500W, you'll be okay with a 3070 and 1600X
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
As Prodigy stated, it could be bad reporting as that would insta'kill your CPU, most likely.
That, or the auto overclocking offset voltage is adding wrong. You'll notice the reported voltage is almost exactly double the shown voltage next to "offset mode". If it were me, I'd disable the auto-overclocking and see what happens.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
Ok. Didnt know that it would be ok with 550w. So if it passes and no overvoltage. What sould i do then? What would be the problem?
As long you don't run anything graphical demanding like a game etc it should be fine...
And if this over voltage problem goes away with the old psu the solution is kind of simple, you need another psu as the one you got is somehow not working properly with your motherboard at least.
Also see sig, my 3070 runs fine... I set power limit to 90 and core clock - 25 and still get above average benchmark results...
I also forgot to apply my settings once and nothing happened... lol.
I'll still use it because better safe than sorry and performance is through the roof EITHER WAY. ;)
-Scott Manley, 2021
Kid.Lazer has the right idea.
Why haven't you reset your BIOS? Honestly thinking that's the play here. We're praying that this is a misreporting error because if it's not your CPU is as good as dead.
I'd say reset your BIOS first then introduce a new PSU, just what I'd do personally.
The CPU is at 35C shouldn't it be really hot with that much voltage? Tho I certainly don't know since there won't be any load, but I still think it should run more hot even idle?
-Scott Manley, 2021
Ok so i switched back to the old PSU and its the same problem. Did the BIOS reset with the screwdriver crosslink and same thing. The only thing i dont know is how to turn of the autooverclock since i dont know whats its name in the bios.
Whats your next advice?
Ok since you reset CMOS there should not be any auto overclocking applied. But this is really a weird situation looks like the motherboard is misreporting, I can't really give any advice here as I've not seen anything like that yet.
Did you actually check this before using the new PSU tho, maybe your mobo always did this?
-Scott Manley, 2021
No, with the old setup i never got that error. Wont even let me pass into windows, i have to press F1 and go into BIOS.
Simce everything else is.new and the old PSU didnt help. Would it be smart to try a new MOBO?
And thank you for your help so much.
I see, actually yes trying a new mobo would be smart as we can't exclude something being wrong with it... *however* if you do this use your old psu or a known good psu because this kind of still looks like the new one was causing all this... you know, something must have caused it, doubt it's the gpu tho, although you could try using your old one if you still have it.
. But anyways, new mobo and old / known to be good psu is what I'd do probably.
-Scott Manley, 2021
