So i have bought a new aio, the pureloop 240mm. It is cooling a r5 3600, when at idle i am getting between 45 and 50 degrees Celsius and after running cinebench for 10 minutes it was at 77 degrees. i have 2 case fans also. Idk much about coolers so do these temps sound right? or did i maybe not plug something in? Cheers!
https://linustechtips.com/topic/1292901-do-these-temps-sound-correct/
I have a 240mm aio on my 3600x as well. It looks about right. But what's your voltage @?  Mine was sitting around 1.365v. I was able to drop it to 1.3v with not performance loss. It also lowered my temps by 10c and I run my fans at a lower rpm which =less noise.
let me try that, thanks for the tip!
