2 things:
1) Steam displays (by default) in bytes, not bits. Internet is referenced in bits. Your max speed of ~55MB/s is around 440Mbps, not amazing but:
2) Depending on the steam server load and your location you can be bottlenecked by other factors such as the local steam server not being able to serve all the connections at once at full speed.
Edit:
You also seem to be having disk write issues, what are you storing your games on? A local drive? NAS? etc.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1291922-download-problem/#findComment-14377651
Yeah, you won't really see almost 1Gbps speeds anywhere outside speed tests mostly
I have 1Gbps and most I've got in a Steam download was around 65MB/s (520Mbps)
Also Steam usually compresses games and the client decompresses them as it downloads, so the processing power available will also affect it
https://linustechtips.com/topic/1291922-download-problem/#findComment-14379014
The sad thing is sometime I can download 25gb games with 100M/bs at once without problems but that is 1 out of 100 downloads.
And that's suspicious.
https://linustechtips.com/topic/1291922-download-problem/#findComment-14379301
I have nothing to add to your actual question.  Just wanted to opine that Steam is...weird...in other languages.  It's a mélange of your language of choice and English.  Shop, Community, and Download are all in English....why?!?
#Muricaparrotgang
Folding@Home Stats | Current PC Loadout:
Small                        Bigger				Biggerer				Biggest
Fractal Design Focus G       NZXT H1				Lian LI O11 Dynamic XL			Fractal Design Meshify C
FX-8320                      Ryzen 3 3200G			Ryzen 5 3600				Ryzen 7 3700X
120mm AIO                    120mm AIO				Custom 280mm loop			Noctua NH-D15
A motherboard                ASRock B450 mobo			MSI x570 mobo				MSI x570 mobo
16gb DDR3                    16gb DDR4 @ 3200			16gb DDR4 @ 3200			16gb DDR4 @ 3600
a melange of HDDs/SSDs       WD 1tb m.2				WD 500gb m.2				WD 1tb m.2/2tb HDD
PNY GTX 1070 x2              GTX 1070				GTX 1070 FE				MSI RTX 2080 TI
some 650w PSU                650W SFX-L 80+ Gold		MSI RTX 2080 Super			EVGA SuperNova 750w 80+ GOLD
								Corsair RM850x 80+ GOLD
https://linustechtips.com/topic/1291922-download-problem/#findComment-14380297
