Problem with Ryzen RAID driver.
So, I have a couple of 1tb 7200 RPM drives on RAID, so I do the bios setup to work as RAID 0.
My PC doesn't recognize them afterwards so I looked online and downloaded AMD RAIDEXpert2 to manage it. I install it without problems and when its done my PC recognizes the RAID drive successfully.
Everything worked as intended. The problem comes when now, a day after, my PC doesn't turn on, and gets into safe boot up. When it self-fixes it uninstalled the RAID drivers, and now my PC doesn't recognize the RAID drive. I tried this a couple of times and M'm sure that the driver is the problem. Any solution? Maybe another kind of driver or configuration in the BIOS ?
Note that i tried to make twice the raid disk in the bios successfully, is Windows that doesn't recognizes it.
https://linustechtips.com/topic/1291817-problem-with-amd-raid-drivers/
It doesnt really belong here any more than it does in Storage (given this is your PC and not a Server or NAS), and a mod would have moved the topic if need be.
This discussion should be continued under the OP
As for your issue drivers/software shouldnt really be removing themselves automatically unless its rolling back to a last known good configuration (which may happen if the system BSOD's and fails to boot Windows. This mode unloads drivers and reverts registry entries to the last time it booted successfully).
AMD Raid has even more problems than Intel's Raid (IRST), so like has already been suggested; I would avoid it. You're also asking for trouble RAID0'ing spinning HDD's.
But if you really want to do it, then either use storage spaces, windows raid or a proper card (HBA's support basic RAID0/1 just fine)
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
