Let's say I need 2tb of data, and I need hard drives only. Let's also say I don't have a lot of money for this amount of storage, but I need it to backup my data. Would second hand 2.5 inch hard drives benefit me or would first hand 3.5 inch hard drives benefit me.
d o u b l e g t x 1 0 8 0 t i p e n e t r a t i o n
https://linustechtips.com/topic/1291073-question-on-drive-types/
If they all run at the same speed/have similar amounts of cache, I'd expect performance to be about the same. But I wouldn't recommend buying hard drives second-hand. They're one of the few components in modern PCs that can experience unexpected mechanical failure, and that rate of failure increases exponentially the more time they spend online.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://pcpartpicker.com/product/mwrYcf/seagate-barracuda-computer-2-tb-35-7200rpm-internal-hard-drive-st2000dm008 heres a 2tb hdd with 256mb cache. less than 60 bucks is still pretty cheap
OUTDATED JAN 2021 ===========> Check out my pc building guide! might be useful tho
It's great for planning new builds, getting a reference on where to start, or seeing what you need to play what games.
It also shows what I recommend for upgrading your stuff!
cpu - ryzen 5 3600
gpu - gtx 1070
ram - (2x8) 3200mhz
ssd - 970 evo plus 500gb
ssd2 - 860 qvo 1tb
mobo - asrock b450m hdv r4.0
psu - evga b5 550w bronze
If you're using these drives to backup data then I wouldn't trust second hand drives.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Beware the SMR, if data needs re-writing at all.
https://blocksandfiles.com/2020/04/15/seagate-2-4-and-8tb-barracuda-and-desktop-hdd-smr/
Don't buy 2nd hand disks, especially not for backup purposes!
@richodude's suggested drive is fine, for  backups. But do be aware that the drive is SMR, not CMR. This basically means it will slow to crawl if you re-write data - eg if you do a full backup of 2TB each time. If you just add files to it, without taking any away, you'll be fine. Read performance is unaffected.
