CyberpowerPC Power supply??
Go to solution Solved by flibberdipper,
I normally don't trust anything other than Corsair or SeaSonic, but... If it has a warranty, I don't see why not.
So I recently ordered a computer from CyberPowerPC and have been reading a lot of bad reviews on there standard power supplies, I don't think it's too late to change, so should I change it for $26 too a corsair 80 plus bronze. Or will this PSU bring me no problems.]
Here are the specs, thanks for reading.
  • *BASE_PRICE: [+1139]
  • BLUETOOTH: None
  • CAS: Raidmax Viper w/ USB 3.0, Side Window Panel [-37] (Black Color)
  • CASUPGRADE: None
  • CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive [-25] (BLACK COLOR)
  • CD2: None
  • COOLANT: Standard Coolant
  • CPU: AMD FX-8350 4.00 GHz Eight-Core AM3+ CPU 8MB L2 Cache & Turbo Core Technology [-20]
  • CS_FAN: Maximum 120MM Case Cooling Fans for your selected case [+9]
  • ENGRAVING: None
  • FA_HDD: None
  • FAN: AMD Certified CPU Fan & Heatsink [-33]
  • FLASHMEDIA: None
  • FREEBIE_VC: None
  • HDD: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
  • HDD2: None
  • HEADSET: None
  • IUSB: Built-in USB 2.0 Ports
  • KEYBOARD: (Keyboard & Mouse Combo) Cooler Master Storm Devastator Gaming Keyboard & Mouse Combo
  • MEMORY: 8GB (4GBx2) DDR3/1866MHz Dual Channel Memory [-59] (Corsair Vengeance [+25])
  • MONITOR: None
  • MONITOR2: None
  • MONITOR3: None
  • MOTHERBOARD: * GIGABYTE 990FXA-UD3 AMD 990 ATX w/ Ultra Durable 3, On/Off Charge, GbLAN, 4 PCIe x16, 2 PCIe x1, 1 PCI
  • MOUSE: None
  • NETWORK: Onboard Gigabit LAN Network
  • NOISEREDUCE1: Sound Absorbing Foam on Side, Top And Bottom panels [+29]
  • OS: Microsoft® Windows 8.1 (64-bit Edition) + Office 365 FREE 30 Days Trial
  • OVERCLOCK: No Overclocking
  • POWERSUPPLY: 600 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
  • RUSH: RUSH!!! READY TO SHIP IN 5 BUSINESS DAYS [+49]
  • SERVICE: STANDARD WARRANTY: 3-YEAR [3 Year Labor, 1 Year Parts] LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
  • SOFT1: McAfee AntiVirus Plus 2014 [+0]
  • SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
  • SPEAKERS: None
  • TEMP: None
  • TVRC: None
  • USBFLASH: None
  • USBHD: None
  • USBX: NZXT Internal USB 6-PORT Expansion Module [+19]
  • VIDEO: NVIDIA GeForce GTX 770 4GB GDDR5 16X PCIe 3.0 Video Card [+154] (EVGA ACX Cooling Edition Powered by NVIDIA)
  • VIDEO2: None
  • VIDEO3: None
  • WNC: None
  • _PRICE: (+1250)
https://linustechtips.com/topic/129070-cyberpowerpc-power-supply/
Looks good to me, I don't think it's necessary to swap out the power supply, but I would worry about longevity. The lower rated power supplies might not be built as well. I have a 1kw power supply from cyberpower and it's still kicking after 5 years.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
