ssd HELP : SSD STATUS [UNUSABLE]
Solved by Tristerin,
Just now, SpicyChiliSause said:
Yes you are right!! This is my external enclosure.
Any way you could move it to a board, format it, then move it to the enclosure? Any other enclosures to try?
1
toxic_worper ·
5
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning6
