I dont know much abt pc building so i thought someone here could help, im getting a Ryzen 3 3300X with a Biostar b550mh motherboard. I need to know if i can buy ddr4 3200mhz 2x8GB ram for this. Will it be compatible or is there a different ram i should get?
Edited by Harvind20
https://linustechtips.com/topic/1290314-i-need-help-choosing-ram/
Yep that ram will be compatible.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
3200MHz - Good
3600MHz - Good (If you can find cheap, or same price as 3200MHz)
Anything above 3600MHz is here say there say, unless you can afford it.
I'm running this right now Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (CMK16GX4M2B3200C16) - PCPartPicker Overclocked from 3200MHz to 3466MHz
If you don't want to, or not into overclocking, just get a kit of 3200MHz - 3600MHz with XMP and just roll with that. If you do overclock, make sure your MCLK and FCLK are the same for example, my Memory Clock is 1733 (x 2 = 3466) and FCLK is 1733 (Half of ram speed) Hope this helps! Good luck!
P.S. what's the price on that mobo? not a big fan of Biostar, haven't used them since AM2+ never had luck with overclocking on them, but who am I to say, I am running an AORUS M and people think they VRMs are ass, but so far I am having good luck with OCing *shrug*
20 hours ago, OGKRG said:
3200MHz - Good
Im not planning to overclock, the biostar motherboard was the cheapest one i could find with a b550 chip since they have pcie gen 4 slots. That will future proof my motherboard. It was abt 70 dollars.
