Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
i have a gtx 1080 FE and im planning on getting a mini itx board for my ryzen 3700x and i have a power supply lined up, im just tryna see what you guys recomend for mini itx cases from personal experince or a friend for cooling cause the ryzen runs decently cool already but the 1080 be getting hot.
https://linustechtips.com/topic/1290126-mini-itx-case/
Presuming the power supply you're going to be using is a regular ATX one and not SFX? That limits recommendations for cases somewhat because the truly tiny ones have to use the smaller SFX PSU's.
Also, you didn't state a budget.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1290126-mini-itx-case/#findComment-14364630
