Seeing as the fans are not spinning, it looks good to me. My 3080 is idling at 30°C, but that's because of water cooling. Yours looks good for a "passive" air cooler.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363165
Yeah the fan curve is set to default. So I assume once the temp hits 60, the fans spool up. Not sure if my fans is causing any idle issues. I did switch up my case fans to RGB... but left my Noctua fans on the bottom blowing up to the card. I'll post a pic to show.
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363170
Since it get's enough cooling from the case fans at idle, it can stop the GPU fans. That's normal. When it's under load the fans will kick in.
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363178
Idle temps are irrelevant, so most cards just stop fans when not under load.
F@H
GPD Win 2
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363179
1 minute ago, Apollyon2020 said:
The bottom is my Noctua fans 3000rpm and the RGB is the Corsair QL140 1250rpm. Maybe I should increase the bottom Noctua fans to blow faster? To help cool the card without it spinning the fans? I dunno lol
Are your case fans running at 3000RPM all the time? That would be deafening.
Your temps are great as-is. I wouldn't change anything.
And if you want lower temps, just adjust the fan curve to not stop the fans at idle and make them spin at 20% or so.
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363182
No no lol I got them at 1600 rpm. 3000 rpm sounds like a damn airplane lmao. Sometimes the GPU idles at 55. Not sure why it's at 57 right now. Maybe there is still warm air in the case lol
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363206
Just nvm these temps. I'd be comfortable with anything at 60 or lower for idle.
Even at 1000RPM noctua fans are just too loud for me lol. I keep my NF-A12x25's idling at 500RPM and slowly climbing to 1000 when the water temp rises. Just shows how different the tastes and preferences are i guess. :D
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363216
33 minutes ago, Apollyon2020 said:
I know when CPU idles real high in the 60s, that'll reduce the life to it.
That's just incorrect.
F@H
GPD Win 2
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363275
Is it incorrect? I remember hearing about this many years ago. Whats the max temp for CPU's to be idling at before they start to degrade?
Lmao... To be honest, my 3 Noctua fans at 1600 RPM I can't really hear them. Maybe it's because my case has some sort of sound dampening? Not sure lol. The 6 Corsair QL140 fans at 1250rpm... makes me feel like they're not doing anything lolll.
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363336
Maybe you just have a much higher noise floor than me. But i also have open-backed headphones, so i basically hear everything as if i'm not weaing any at all.
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363507
around 95-115C
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363509
As long as it's under the max temp spec it's fine.
F@H
GPD Win 2
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14363683
On 1/5/2021 at 7:56 AM, Apollyon2020 said:
Was wondering what everyone else is getting. This is what I'm getting. These idle temps fine? On load, it goes up to 74-76 degree's celsius.
Idle from a cold boot I am getting a low as 24 degree on my RTX 3090 FE and while gaming 1080P 240Hz Ultra settings getting 60-66 degrees
SFF Time N-ATX V2 - Gigabyte X570 I Aorus Pro WIFI - AMD Ryzen 9 5800X3D - Gigabyte Gaming OC RTX 4090 - LG C2 OLED 42"
https://linustechtips.com/topic/1289951-rtx-3090-idle-temps/#findComment-14385728
