Hello, i have Ryzen5 3600X CPU and a Stock Cooler, when idle it works on 35-40C, when using web browser it goes to 50-55C, but when playing games (Kingdom Come Deliverance, GTA V, ArmA 3..) it goes to 75-85C. So im asking is that normal, i replaced termal paste yesterday, i use some Cooler Master paste... And what Cooler you recomend me to buy, that will lower these temps down, but in the same time wont be so loud?
https://linustechtips.com/topic/1289134-cpu-temps/
normal with the stock cooler. If you want lower, would recommend investing in a decent aftermarket cooler.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1289134-cpu-temps/#findComment-14356672
That's expected temps on a stock cooler, especially if your case airflow isn't great
For cooler, a dark rock (pro) 4 or nh-d15, though make sure your case will fit them
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1289134-cpu-temps/#findComment-14356674
How much money do you intend to spend? Some thermal paste won't be making all the difference, but an inexpensive tower cooler will do the job, like the cooler master Hyper 212 black.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1289134-cpu-temps/#findComment-14356778
I could spend 30-35euros. I will take a look in your suggestions, thaks!
https://linustechtips.com/topic/1289134-cpu-temps/#findComment-14357018
