corsair 360 aio
leonardmartin29
****decided to stay with the cpu cooler i have dont wanna spend 300$+ for looks i can spend that money on a better gpu or something
here are my specs
intel 10850k
asus tuf z490 plus wifi
corsair vengeance lpx 2x16gb 3200mhz
2x samsung 970 evo plus 1tb
corsair commander fan controller
corsair hx850i psu
noctua nh d15 chromax black
6x noctua nf-a14 chromax black fans
evga gtx680
im thinking about putting in a 360 rad on top for the cpu (no current thermal issues just for looks)
what does everyone think of corsair's aio's any problems with them i will only go with corsair because it runs on corsair icue and i have it already for my other parts and i dont want anymore junk software taking up space
also since i have 6 noctua fans 2 of them will have to be swapped out for 3 120 of noctua fans that match. i hate rgb so i wont be using the corsair fans
360 is a long boi, can it fit?
Does the 360 fit?
use software but not really using it? Cover it all up!
Does the 360 fit?
it says it can fit a 360 rad on top and one on front as well
Which one? If your want the best in rgb the and controlling the light effects then corsair is the best.
Otherwise better options in performance and noise would be
Ek-aio still has great argb and lighting effects will be dependent on what your motherboard supports
Best all black aio's
Artic liquid freezer II
alphacool eisbaer
alphacool eisbaer
i want a corsair one thats for sure just so i can use the corsair icue software for the pump and things like fans etc. i already have the software which i use for other parts. i dont want rgb and will be changing out any rgb fans to noctua fans chromax black.
i just want a quality basic 360 aio from corsair
If you dont want any corsair features then why get corsair? And if your dead set on getting a corsair aio then why bother asking your question?
Second
The p12 fans that come on the arctic liquid freezer II are just as good a the NH fans. So you wouldnt have to replace them.
You can check out gamers nexus video on them.
The 3 aio I mentioned all stomp corsairs aios in performance and noise levels
Second
i choose corsair because of the software for the pump. if i choose a different brand i have to download different software for their pump.
as for fans i would like to stick with noctua as i already have 6 noctua and for looks i dont want them to be mismatching plus im still debabting on sticking with what i got and spend the money on a better gpu
There is not much you can with pump speed in icue anyways and as far as controlling fan speeds there are many option that can do the same that dont require icue
this convo is done because you dont seem to have the common sense to comprend what i am talking about
You wont have to download anything as pump speed is set in the bios. So no software is needed. As for the fans you can control them from the bios as well. if you already have a CCP. Then you can connect it to them. Either will work.
sorry i didnt know pumps were handled in the bios thats good then it doesnt matter about brand for aio although im thinking about doing a custom loop for cpu as well something way overkill like a dual 360 rad with both at push/pull so 6 fans on each rad.
