GPU Clock Speed Questions
Go to solution Solved by MadPistol,
That is the idle speeds. Fire up a game and it will clock up to (and past) the speeds you mentioned.
Hello, I just completed my first build, and I noticed something about my GPU clocks and I had some questions. So on MSI Afterburner, it is showing something like this:
This is not what the advertised base clock speed of the card it, and it also shows 0 for the voltage, which I am not sure is correct. Sometimes, it will spike the 1666 mHz/7000mHz, but it usually stays around the clocks in the picture. Is this normal, or do I have to do something to fix this? Everything (games, productivity) still works, so not sure what the problem is here.
https://linustechtips.com/topic/1288870-gpu-clock-speed-questions/
CPU: Ryzen 7 5800x3D || GPU: Gigabyte Windforce RTX 4090 || Memory: 32GB Corsair 3200mhz DDR4 || Motherboard: MSI B450 Tomahawk || SSD1: 500 GB Samsung 850 EVO M.2 (OS drive) || SSD2: 500 GB Samsung 860 EVO SATA (Cache Drive via PrimoCache) || Spinning Disks: 3 x 4TB Western Digital Blue HDD (RAID 0) || Monitor: LG CX 55" OLED TV || Sound: Schiit Stack (Modi 2/Magni 3) - Sennheiser HD 598, HiFiMan HE 400i || Keyboard: Logitech G915 TKL || Mouse: Logitech G502 Lightspeed || PSU: EVGA 1300-watt G+ PSU || Case: Fractal Design Pop XL Air
You'll have to enable voltage control and monitoring in Afterburner settings:
https://i.gyazo.com/23383921d20a7043f203b9eb99cd4dc6.png
Update Afterburner if you haven't already just to make sure it has support for Ampere.
