Need help choosing between Graphics Cards
Solved by .Apex.,
19 minutes ago, MesZa said:Originally, I jumped at the chance to get the 3060 Ti, but I looked at the Core Clocks and became skeptical. The Core Clock for the 3060 Ti is 1410 MHz (with a boost clock of 1710 MHz) and the Core Clock for the 5700 XT is 1650 MHz (with a boost clock of 1905 MHz)
Also because of how GPU Boost works, regardless of what their stock clock specifications are, both GPUs would actually clock similarly ranging between 1900-2000Mhz, but it's irrelevant once again, just pointing that out
