Are my temps to high?
Oakryx
So I have a evga ftw3 ultra 3080 and I've been messing around with different settings in games and I've noticed in destiny 2 and overwatch I'm seeing my graphics card at 100% usage and sitting around 79 to 80 degrees. But I do have all of the setting maxed out at 1080p and I also put the render scales up to 200 on both games. I was just wondering if these temps where to high for my card. Thanks for any help.
GPU can survive up to 100c, so 80c is normal.
Using the Precision X1 aggressive fan curve my card runs around 65 degrees at 100% usage. What's your fan curve like? And I've got the XC3 Ultra so your card has a better cooler and should run even lower than that.
i've not seen a ftw3 above 70C, whats the airflow like and ambient temp?
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Air flow through the case is pretty good its a cooler master nr600 and the ambient is about 75 degrees f
1 minute ago, Oakryx said:
I would try going a bit more aggressive or use the aggressive preset, I believe it sets 80% fan speed at 70 degrees but I'm not at my pc to check at the moment. When I was using the default initially my temps got up to 77 so the aggressive curve made a huge difference.
Alrighty I'll give it a try
I switched it to the aggressive settings and ran some d2 for a bit and yah it dropped down and it peaked at 71 with 100 percentage usage
