Trying to enforce stock settings on z490 Ultra
20 minutes ago, FeIIex said:Specs:
i9 10900k with Artic Freezer II 240mm AIO
Gigabyte z490 Ultra
32GB 4x8 Patriot Viper running at 4266 cl19 with 1.35vEVGA 1080ti SC2
I put this rig together last monday, and have been having issues with stability and temps. I had intended to overclock in the future after doing research, but this motherboard factory overclocks my cpu causing it to hit 100C under full load. I just want it to run at stock settings for the time being, but there is no option to disable this overclock from within the bios. There is the option to manually change settings, but being an OC noob, I have no idea what I am doing.
Settings that I have changed from default:
Enhanced Multicore-performance, set to disabled
Vcore switched from auto to fixed (Auto would bring it to 1.45V)
Vcore is set to 1.365v which is MOSTLY stable with the occasional crash here and there. But even with this set, it still climbs to 1.5v at times.
I have not altered anything else other than enabling my XMP profile. (I imagine there are more items I need to change to fully enforce stock, as the the CPU runs at 5.1GHz all core nearly constantly) Are these voltages even healthy?
As a side note, how accurate is HWMonitor as a utility to measure temps? Thanks in advance.
BIOS update..? I would do that first.
