Need help removing a script from my PC
I got the dreaded "activate windows 10" watermark on my pc and got my dad to help me out with it. He opened up this video on youtube with a script in the description, and then copy pasted into text file, then ran it in CMD. This has really made very anxious, to the point I want to get rid of it and by a legit win10 key.
Please help.
https://linustechtips.com/topic/1286985-need-help-removing-a-script-from-my-pc/
Ok so im not 100% farmilliar with so im guessing unless someone else who knows more comes.
So it was just a script that was run once, which activated windows with an 'fake' organizer activation.
So, firstly run a virus scan to remove the actual program. You can turn windows defender back on, or run Malwarebytes (also recommend running AdwCleaner if u never run it before).
https://www.malwarebytes.com/
https://www.malwarebytes.com/adwcleaner/
Then once you got your own activation code, im hoping you should be able to do it from here:
And just enter your key instead.
it works from microsofts KMS
https://docs.microsoft.com/en-us/previous-versions/tn-archive/ff793434(v=technet.10)?redirectedfrom=MSDN
I'm not 100% sure but i think after a few months it will probably stop working again anyway and will need to be redone so its best to get your own key (ebay hint hint).
@The Torrent, part of your post as well as @Reddaye's reply have been removed. Both are violations of our rules on piracy. Linking, asking links or giving advice on any "alternative" Windows activations is not allowed. There's 0 need to see the link, the content can be read from context of this thread.
-> Moved to Windows
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
1 hour ago, Reddaye said:
Just did a full system scan with BitDefender and it removed the hack tool, everything else came back clean, so hopefully no malware. Just one more thing, will any win10 product key work?
yea get a home windows 10 one.
-> Moved to Windows
Apologies, asked for the link to see exactly what it was otherwise its difficult to tell someone how to remove something if you dont know if its an actual program, runs once script that changes registry or maybe even an application etc. Ill keep this in mind next time.
I understand what you were after. However, the video or its description is still violating our rules and would be removed.
Judging by the video, the script might have connected me to a server. Just to be safe, any way to sever my connection to it?
It disconnected when you stopped running the script, i believe from my limited knowledge it connected you to a fake server temproarily to make your microsoft activation be activated by that 'group', read that link i sent on an earlier post for more info on how it worked.
